Can't add radius to dimension to fillet in drawing cross-section view
tedbradley314
tedbradley314
See video attached.
I need to add a radius dimension to a fillet, but it won't select.
Any helps is appreciated.
And/or I'd like to note this bug to the Fusion team.
Ted
tedbradley314
I guess there was a glitch with Fusion.
Because I deleted the detail view, deleted the cross section view, and then re-created the cross section view, and then re-created the detail view and the dimension works just fine.
@Steven_Gao
tedbradley314
@Steven_Gao Hi Steven, bug report above. Thanks
Steven_Gao
Sorry for the late response. I'll check it and let you know sooner.
Steven_Gao
I used a similar model to try the workflow but it seems working on my side. From your video, it seems the arc not be recognized. Is it possible the section view is not through the center?
