Can only move canvas up and sideways, not back and forth
maxattack611
maxattack611
g-andresen
Canvases are fixed to a plane (e.g. XY) or a body surface and can therefore only be moved on this plane.
A shift in Z is done by shifting the plane or the body surface in this direction.
günther
TheCADWhisperer
maxattack611
Here you go! Thanks for the reply. I would also like to ask as a somewhat beginner in Fusion, Is this an achievable model?  Messing around with the free form tool is tricky, and wanted to know how I could get a start on the helmet. the base shape is my main concern. Thank you so much!
jeff_strater
I am able to move that canvas in all directions, see screencast below.
Yes, that helmet is achievable, but it is not a beginner project.  You could use either solid or surface model approaches, I believe.  Start with some good beginner training videos, including the Fusion ones here:  https://help.autodesk.com/view/fusion360/ENU/courses/
Jeff Strater
Engineering Director
TheCADWhisperer
I did not see you move the canvas image in the Y direction. I think that is the OP's question. The canvas will have to be placed on an offset workplane that can be moved in Y.
