Cam and follower only turning 45 degrees
89101363
89101363
Community Visitor
Community Visitor
I animate the joints, and they only turn by 45 degrees before warping to the other side.  I followed a few different guides on how to make this work, and even tried on my own, but this is always the result.  What is causing this?
jhackney1972
It is probably your cam follower is too sharp, Fusion does not work well with such a contact point.  Please attach your assembly.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
