I'm, getting a new Mac to replace my 16GB Mac Mini M1 and am trying to work out what I need for the best Fusion 360 performance.
I'm finding the M1 Mac Mini taking quite some time to do calculations, especially around fillets and embossed text. The Parametric text plugin is great, but that really slows things down 🙂
I've read the minimum specs and that's really not helped me, most of the posts I've read indicate that Fusion 360 doesn't really take advantage of the GPU's on a Mac Silcon except for rendering. It appears to be single threaded cores that give greatest benefit. All the calculations appear to be done in the CPU.
No one seems to talk a great deal about memory, would 24GB be massively better than 16GB, or should 32GB or even 36GB help?
Would a fast single core speed be the best and the fact that it has 10 CPU cores vs 12 CPU cores or even 14 CPU cores make no difference? (apart from rendering, which I don't do a great deal of).
A refurbished M2 Max is significantly cheaper than a new M3 Max.
With the new Apple silcon range, you can't spec a large amount of memory on a small CPU count, so the price goes up quickly.
Any thoughts and tops welcomed.
many thanjks
Rob
