Bugs in the new joint implementation
jaharley
jaharley
Is anyone else seeing joint issues with the recent updates?  I am on 2.0.7813 and a formerly working assembly now shows "Compute Failed" on a ball joint.  Interestingly, with that ball joint in place, all the subsequent joints in the file also will not compute.  Another issue I have seen is that when exporting some of that STEP file (unrelated parts to the ball joint), my assembly was scrambled, but it came out OK as an IGES.
Jonah
jeff_strater
@jaharley - can you share the design that is showing this behavior?  Preferably a back version of it, when it was working.  We can test it on the old and new builds to see if this is really a change in behavior or not.  Thanks.
Jeff Strater
Engineering Director
jaharley
Hi Jeff, I'd be happy to.   Can I send it to you directly rather than posting (it has some confidential features)?  If posting is the only option, I'll have to spend some time stripping it down.  Thanks.
jeff_strater
certainly.  Use the "Share Public Link" option from this article:  How-to-share-a-Fusion-360-design , and then paste the link into a Direct Message to me on this forum.  Thanks!
Jeff Strater
