Bugs in Mirror tool
Bugs in Mirror tool
Prophet_Barnes
Bugs in Mirror tool
Prophet_Barnes
I have been encountering this bug for a long time and it hasn't been resolved yet.
Everytime you go back to edit a mirror feature, you aren't really able to edit the selections, neither add or exclude bodies. Even if you try to clear the previous selection and make a new one in the same feature, the feature only allows you to select entities once. After that, it doesn't allow you to select entities anymore. Kind of frustrates, because the only resolution for this becomes deleting the mirror feature and making a new one at the same history mark, which also results to you losing references of the mirror feature.
Effectively, this messes up with the whole idea of parametric modelling.
KristianLaholm
When editing the selection hold down [CTRL] ([CMD]) and click on bodies.
Screencast example here: https://knowledge.autodesk.com/community/screencast/f7ffe402-1ed5-4cb9-af55-d2f6fe152562
Does this solve the problem for you?
Prophet_Barnes
  • Thanks a lot Kristian!
What you told has worked for me. So, I guess this was about interface rather than being a bug in the tool. Thanks for enlightening me with the same! 🙂
