Bug with Turning CAM Setup and Stock From Solid, Makes Origin Huge
euclidmandd
euclidmandd
I've got some weird behavior when I select stock "from solid" within a turning setup where the origin becomes far bigger than the part, which makes it impossible to select other features like rotary axis, or ironically where I want the origin.  It's not a huge deal once all the setup is done, other than displaying the huge origin when rotating the view with the setup selected.
For now as a work around I'm able to get everything else squared away in the setup with stock set to fixed cylinder and then do the change to "from solid" as the last step.
I'm running on Windows 10 and this just started happening a week or so ago.  This behavior doesn't seem to happen with milling setups.
paul.clauss
Hi @euclidmandd
Thanks for posting! This is a known issue, logged internally as CAM-15360. The development team is currently investigating a fix for a future update to Fusion 360 and I've made a note of this thread on their ticket.
There is no way to avoid this issue in the current build, but it does appear to be a purely cosmetic issue that disappears as long as the CAM setup is not actively being edited. Please let me know if you see any problem behavior that seems like it could be related to this issue.
Paul Clauss
Product Support Specialist
euclidmandd
Cool. Glad to know someone's working on it.
