Bug with split tool applied to a 90 degree loft.
burton_reads
burton_reads
I added to a body using sweeps between sketches set at 90 degrees. When I tried splitting the body at one sketch (before the loft), it fails. You can see this by splitting using the only body, and the "broken split" plane. Offsetting that plane instead of leaving it at 0.0 allows it to split.
This isn't a problem for me, I was splitting it to 3D print part of it to test the fit. But I'm reporting this bug in case it's helpful.
jhackney1972
You are not real clear on which sketch you mean.  Specify a name please.
John Hackney, Retired
