Bug with search feature
SGoldthwaite
SGoldthwaite
I have a project called "Drawer Shadowboxes".  When I search on my projects for "Drawer" nothing is returned.  See screenshots below.     If I search on "Shadowboxes" it works properly.
abhinav_singh
This is working fine for me. Whether I search via the first name or the last name of the item, I am getting the desired result.
Could you pls make sure that you are searching for your item in the right Team hub (after saving the file)?
Abhinav Singh
Product Owner
SGoldthwaite
It's all the same Team Hub. As I mentioned, when I search on "Shadowboxes" it works. I'm not switching team hubs and then searching on "Shadowboxes".
abhinav_singh
Is it happening only for this particular file?
Here is a screenshot from my Fusion. Search correctly picking the first, 2nd, or 3rd part of the file name.
Abhinav Singh
Product Owner
SGoldthwaite
Yes, I think it's just this file.  It seems to work fine for everything else I've tried.  It's really strange that it's just this one.  I even renamed the file, it still started with "Drawer", but that didn't help.
abhinav_singh
Ok, it seems there is not much we can do here then.
But, in case you happen to identify a way to consistently reproduce this issue, do let us know. Thanks.
Abhinav Singh
Product Owner
