Bug with Pipe tool
Bug with Pipe tool
Prophet_Barnes
Bug with Pipe tool
Prophet_Barnes
After the recent maintenance, the pipe tool has started to misbehave. With the hollow option checked, the tool is still creating solid pipes again and again. Only hit and trial is making it work, i.e., trying different combinations and sequences- unchecking and checking the hollow. This is mainly a bug. Please fix it ASAP. At present I have to check at every point of time if the pipes created are hollow, which is kind of frustrating.
g-andresen
I have tested several times in different ways and cannot confirm the behaviour.
Maybe a reboot or a CLEAN UNINSTALL will help.
günther
jeff_strater
reported here:  after-update-2-0-10244-pipe-command-has-issues and a fix is in progress
Jeff Strater
Engineering Director
Prophet_Barnes
Oh. Can you confirm one or two ways for me? One is simply using the pipe tool a second time in a model. And the other is editing a pipe feature in which, changing the path of the pipe feature (including or excluding some curves) may do.
Prophet_Barnes
Oh. Thank you for tagging!
