Bug with holes pattern
ar.rudtp
Message 1 of 11
ar.rudtp
Got some strange behavior today.
Made few holes with 'All' extent. Patterned feature. Ooops - patterned intents are not 'all' extent but just some value.
Replies (10)
Message 2 of 11
ar.rudtp
Update: extension 'to object' fails in same way.
Message 3 of 11
Phil.E
Thanks for the report and model.
Use Pattern : Faces instead of features.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 11
ar.rudtp
It's easy to solve using distance with value far long as expected height of body to cut.
But if we have 'All' and 'To object' options - natural expect they will produce same result as with extrusion of circular profile, right?
Message 5 of 11
Phil.E
Yes that is a good expectation. It's logged as a bug, thanks for letting us know.
There is another option you should be aware of:
Aside from patterning faces, you can also change the compute option.
In general, if you feel something like this is a bug, please report it. And also explore the dialog boxes for options. Whenever patterning, if the default settings give unexpected results, try other options.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 6 of 11
ar.rudtp
Good point!
'Optimised' works as expected.
Is there any description of algorithm behind 'adjusted' and 'optimised'? Names are not very self-explanative for them...
Message 7 of 11
Phil.E
Sure, things like this are explained in the help section/product documentation.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-27ECCED2-6E46-4264-9928-64EEA05899D6
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 11
ar.rudtp
For 'optimised' it's just tell it's good for large quantities, but doesn't describe nothing else about it's differences from 'Adjusted'.
Message 9 of 11
jeff_strater
here is the short version of an answer to your question.  Hopefully it addresses your request for information.
  1. Face pattern and Feature/Optimized are exactly the same.  The only difference is in what is selected (Faces vs Timeline features).  In this option, the actual faces that are selected are patterned, then stitched into the destination body.  This option is the fastest, but the least robust.  Face patterns can fail more easily than others types
  2. Feature/Identical pattern is the next fastest, and more robust.  In this pattern type, the selected features must form a self-contained body.  So, an extrude with a fillet is OK, but just a fillet would not be.  In this option, the body is extracted and patterned, and at the end of that process, all the patterned bodies are joined to the destination body.
  3. Feature/Adjust pattern is the slowest of all.  It should really only be used in cases where it is needed.  Adjust patterns copy the internal data model of the features being patterned, and re-execute those features for each instance of the pattern.  It is useful for patterning things like to-face extrude features, where the target face is not a plane (imagine a curvy spline face or a cone).
Jeff Strater
Engineering Director
Message 10 of 11
ar.rudtp
Thanks for explanation, Jeff!
Message 11 of 11
josh.laycock
Thanks Phil.
Was trying to make a parametrically driven aluminium extrusion with holes in it.  Had weird results when changing profile length and some of the user made parameters.
Changing the COMPUTE OPTION made everything work.
Very helpful, thank you.
