Bug with carry-forward of parameterised hole size
If you have a parameter for hole size, say my_hole_size = 6.5mm, you can enter this in the dialog box when you create a hole.
When you create the next hole, Fusion 360 helpfully gives you a hole the same size as before. However, it has replaced the parameter name in the dialog box (my_hole_size) with the value of the parameter (6.5mm).
The problem with this is if you do not notice that this has happened. If you then change the parameter value, you will find the first holes you created adjust their size, but not any later ones.
Julian
