[BUG] when creating a construction plane at angle.
TrippyLighting
Consultant Consultant
Message 1 of 13
TrippyLighting
Here is a horrible bug that must have been introduced with the update last night and the construction plane code.
Iv'e done this several times in perspective and ortho mode with different backgrounds.
When creating the plane at angle the screen goes blank and the view cube also vanishes. Zoom to fit does nothing!
No sketch or body visible. This is pretty devastating!
Replies (12)
Message 2 of 13
0502880
Hi!
Noticed same problem. I tried to restart Fusion + my computer and it changed the situation so, that the command didn't make the screen blank but the construction plane didn't appear visible.
-Juha A.
Message 3 of 13
radzimir
You can probably work around the problem until it is fixed by placing a help-sketch on the invisible angled plane. The sketch is then visible and is helping you locate a plane. You can rename both with some useful name.
Do not touch visibility bulb for all sketches and all planes – this makes all objects irrevocably invisible until you reopen the file. Select and unselect planes or sketches individually.
PS: in one case after "extruding to plane" one invisible angled plane just reappeared.
Message 4 of 13
TrippyLighting
Thanks. I know how to work around it. Workarounds take time. We just need this fixed.
Message 5 of 13
julia.paganucci
Autodesk Support
Autodesk Support
Hi @TrippyLighting
Thank you for bringing this to our attention! I was able to reproduce this and will log it with the development team.
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 6 of 13
radzimir
Addendum: the whole scene disappears if new corrupted angled plane is the only one "visible".
Turn visibility on for some other plane as work around.
Message 7 of 13
bc.protheroe
Hi guys ...
First post so be gentle !!
I too noticed this as being a bug that is frustrating the hell out of me. This is definitely an issue with the latest update as the tool was working absolutely fine until today when I restarted Fusion 360 to update.
In my case, I have 2 canvasses that I am using to construct the fuselage of this aircraft. Having created a sketch (in the vertical origin plane), I drew a datum line. Using the Plane at Angle tool (again, working absolutely fine yesterday), and selecting the line just drawn caused the whole project to disappear. I've hopefully attached a screencast of the problem.
Any ideas as to when this fairly fundamental issue is likely to be resolved ?
Kind regards
Ben
Message 8 of 13
jeff_strater
this bug has been fixed, and an update was just pushed.  Sorry for the disruption
Jeff Strater
Engineering Director
Message 9 of 13
TrippyLighting
Thank you very much!
Message 10 of 13
gymnyan-man
I appreciate the quick discovery and correction of the problem.
The same problem became a topic late one day in the Japanese forum.
But thanks to this topic, we did not last long on the problem.
Big thanks.
Message 11 of 13
rbtyod
The "invisible planes at an angle" problem may have been fixed in 2019 but here I am in 2024 with the same problem!
I know the plane is there because I can sketch on it, but I wasted a lot of time finding that out! I hope you can get it fixed quickly.
... Bob
Message 12 of 13
rbtyod
I know this problem was fixed in 2019 but here I am in 2024 with the same problem! I found that the plane is there by selecting the place where the plane should be and making a sketch. I hope you can get this fixed again quickly.
... Bob
Message 13 of 13
never0101
Observer
Observer
This is still a problem - except when when the whole screen goes blank if i hit enter to make the plane fusion crashes
