Bug? Tangent constraint shown is false. It's actually removed in the process. (zoom video)
acoleman10
acoleman10
Hi there,
I use the attached drawing to show using all 5 slot tools. When the center 1" hole is trimmed the tangent at the far right end of the slot are removed but one still shows. This is repeatable and figured would go away at some point.
Also when using a 3 pt slot the third click does not constrain to the selected point, only the end points. Figure that is just normal. (I also show this in the video)
Thank you!
https://wccnet-edu.zoom.us/rec/share/zwvz4Qxl4ksaFz8GpyJfBJbXfLgk1s8lRbn1IF711d8rNaYIrI1dzadujTRiEW3...
Passcode: 6^jQbKhV
sameer_babarNJS6C
@acoleman10   Sorry for the inconvenience caused & Thank you for sharing the data . We could reproduce the issue at our end from scratch with the help of video file provided by you, it is likely due to displaying constraints at incorrect location after using trim command but our team will analyse it further more.
We have logged an issue FUS-150739 for it & we are looking for the solution .
"If you find my answer solved your question, please select the Accept Solution icon"
Sameer Babar.
Autodesk Fusion 360 Team
