Bug - Stuck progress bar
RDTymko
RDTymko
Just in the last couple of days once I have fusion open and attempt to open a second file fusion switches to a second window loads  the file along with a loading progress bar. Fusion then jumps back to the original window with the second file opened but the progress bar is stuck in the middle of the screen. The only way to get rid of it is too close fusion and then restart it.
This has happened 3 separate times in the last two days.
any ideas?
HughesTooling
When it happens again check the task bar and see is Fusion has 2 stacked icons. If it has you should see a preview of Fusion and one for the progress bar, mouse over the bar preview and click the red X to close.
Mark
Mark Hughes
Owner, Hughes Tooling
RDTymko
This bug is still plaguing me.  It seems to happen most often when I import a STEP file then try and open it.  This happens with several different imports.
See the video that I uploaded of the bug...
Richard
larsboelman
I have the same problem on my Mac. No option to close the progress bar separately it seems.
