Bug: Sketch objects no longer movable
spawnreaper
spawnreaper
Since yesterdays update I can no longer move sketched objects while editing sketches. If I activate the move command while in sketch edit mode I can not select any sketch objects.
I’ve tried reopening the document but the problem remains. The object is not constrained in any way. Even if it was I would still be able to select the lines. I’ve posted this in the Facebook fusion 360 user group and it seems that more people are experiencing the same issue.
g-andresen
1. show this behaviour in a screencast
2. Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
HughesTooling
Are any of your selection filters unchecked?
Mark Hughes
Owner, Hughes Tooling
spawnreaper
Yesterday I did check the selection option but even though the move object was open the select sketch object was not available in the selection list, which makes no sense because that's the only selectable option you have during sketching.
I just now started my laptop again. Now for some reason I was able to select and move. Nothing changed. If it happens again I will record the behaviour and make more screenshots. For now this is resolved.
I stil think its some kind of bug.
