Bug: Sketch is marked as fully contrained, although it is not
Bjanders
Bjanders
Here's a sketch that I created. The document browser on the left shows that the sketch is fully constrained. However, there is a point in the sketch, the notch at the top, that is not constrained. As you can see in the screencast I can drag the point with my mouse.
I'm using version 2.0.14337.
I've attached an export Fusion 360 file.
Edit: I forgot to press "Insert" when adding the screencast. Now when I try to add it I get the error "Your post has been changed because invalid HTML was found in the message body. I tried both pasting a screencast URL and inserting from "My screencasts". When pasting the URL if first displays ok while still editing, but when I press "Post" I get the error and the screencast is removed. You can probably find it from my profile if needed.
Edit2: Here's the screencast URL, since "Paste a screencast URL" does not work: https://screencast.autodesk.com/Embed/Timeline/02115ef6-f34a-425b-899f-529c15c71ef5
TrippyLighting
Yep, that certainly is a bug. @Phil.E
Phil.E
FUS-114913 is logged for this. Thanks for the example and heads up.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
This might help with screencasts.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
