Hello everyone,
I seem to have a (file specific) issue with the simple selection of a joint in the timeline. Here is my model before the bug:
I can select the joint marked as 2 just fine. It highlitghts just the symbol on 3D view as per usual.
However if I left/right click any of the joints in red (first 2 marked as 1, but applies to all joints to their right in red) the whole model is highlighted (as if everything including all joints and sketches were selected with the mouse window selection):
This selection does not go away unless I close the file, and I can replicate the behaviour after opening it again. This makes it impossible to work with these joints or the model (since I can't see anything).
Notably some of these joints have been generated with the new command "Duplicate With Joints", but so have the green joints. Other files I have tested work just as expected.
Help with this issue would be much appreciated!
Greetings,
Magnus
