BUG(s): text objects
Alright, found a couple issues with the text object in sketches...
I'm using a text object to extrude labels into my design to identify a part/product..
issue #1: I can't drive the text object with a parameter....(I am also a skilled spreadsheet designer/programmer, and I have not found any way to make this work yet...)
issue #2: upon updating the text object for different sized parts, the update DESTROYS all constraints/dimensions...
I just spent a few hours making a parameter driven design.... that is utter broken at the end because of this... 😞
kate.raskauskas
Hi @Anonymous,
Oh no, I'm sorry to hear that!
What parameters are you trying to use to drive your text? And can you tell me more about how you tried updating the text for different sized parts? (If you're able to make a screencast so I can see your workflow that would help in figuring out the root cause of the issue)
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
