Bug report: Unable to save changed document
Kekht
Kekht
Hi
This issue apeears too often. After some time I work on my document (making changes), the "Save" button and "Save" menu item (under File menu) becomes grayed (but asterisk near file name indicates that document have unsaved changes). It could happen at random period of time of my work. for now the only solution in this case, to not lose changes - is to use "Save as" (wich works) but leads to littering of project and resetting of version number.
I have Personal licence, but Capacity is 2 of 10, so there is space for saving (and "Save as" works").
Here is screenshot:
Fusion360DiagnosticLogs.zip attached
Best regards,
Andrey
dsouzasujay
Hi @Kekht ,
This posting about a week old. Do you still need assistance?
Are you still facing problem saving the documents?
  • Try deleting the file APPDATA/Autodesk/Neutron Platform/Options/NMachineSpecificOptions.xml
  • Restart Fusion 360
See if you can Save the document
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
