Bug report: Sketch dimension displayed with decimal point wrong place
tvornbrock
tvornbrock
While sketching a circle I noticed the dimension displayed was off by one order of magnitude from the value entered (entered as 1.935" but displayed as 0.1935". However, when I hover the cursor next to the incorrectly displayed value, the correct (as entered value: 1.935") was displayed (see in the screenshot the inconsistent values right next to each other).
Anyone notice this before? Note the inconsistent dimension valuesNote the inconsistent dimension values
g-andresen
are you sure?
günther
tvornbrock
Do you think it's OK to make fun of dyslexic people?! LOL... But, seriously, why does the d5 dimension display as the circle's diameter while the dimension indicated by the dimension arrow/leader refer to the wall thickness? I assume the d5 is the internal controlling dimension, but this risks confusion, no?
jeff_strater
this feels to me more like a discrepancy between the document's unit display type and the value typed into the dimension.   For instance, I have a mm design, but I created this rectangle, typing in "1 in" for one dimension, and "10 cm" for the other:
Screen Shot 2021-02-24 at 10.56.23 AM.pngScreen Shot 2021-02-24 at 10.56.28 AM.png
the hover value shows what I typed, the static display uses the document's units.
Again, if you can share the design, it will be easier to determine
Jeff Strater
Engineering Director
tvornbrock
Thanks for your help. I see what happened in this case. It was a rare situation where the would wall thickness displayed happened to be a value similar to a fraction of the the diameter, which is what the hover value refers to. I expected the hover value to refer to the dimension indicated by the arrow/leader lines. I'm new to using F360.
