Bug report - pressing the TAB key on a float slider crashes Fusion 360
OceanHydroAU
OceanHydroAU
Reproduce by running your "Command Inputs API Sample" code (after moving line 29 up to line 14 to fix the bug so it runs):-
   https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-00eeff48-1ca1-4b01-b31c-dee24efa4975
click on the first of the 2 number in the first "Float Slider" control, then press the tab button on your keyboard.
nnikbin
My add-in uses integer sliders with two fields. They have the same problem. I want to release the add-in in 10 days. I would like to know what is Autodesk's schedule for fixing this bug and should I replace each slider with two sliders?
goyals
I am able to reproduce it and logged FUS-65979 in our bug tracking system. It looks a window specific issue. It might be late to target it for next Fusion release i.e in June but we will definitely consider it for the release after. Thanks for posting it.
Shyam Goyal
Sr. Software Dev. Manager
nnikbin
Thank you @goyals for your reply and logging the bug in your bug tracking system.
