Bug report: Incorrect keyboard shortcut written in tooltip on macOS (ctrl vs command)
andrewKQMJ7
Observer Observer
andrewKQMJ7
Observer
Observer
@autodesk:
When in PCB or Schematic view, there's an icon button to flip between the two respective views. When you hover over the button, it shows that the shortcut is "Ctrl+1" / "Ctrl+2". I'm sure this is true on Windows but on macOS it is in fact "Command+1" / "Command+2".
The fix required would only be a text change in the tool tip.
lance.carocci
Great find, @andrewKQMJ7. I will pass this along to the ECAD team. It looks like other commands like Copy in the ECAD workspace have this issue too.
For what it's worth, we do have some hotkeys bound to CTRL on macOS (View toolbar in the Design workspace > Visual Style), but they use the Caret (^) symbol. As you correctly noted, the use of "CTRL" is definitely a Windows-ism.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Closed-Loop-Bot
We're happy to report this issue has been resolved. Update Fusion to the most recent version to apply the fix. If this update resolved your issue, feel free to click the "Accept Solution" button to help other community members find the answer more easily. If the issue persists after updating, don't hesitate to reach out to us by replying to this thread. We're here to help! Let us know if you need any further assistance!
