I have a sketch with some projected geometry. One of the projected lines cannot be deleted. I can right click it and click delete and nothing happens. I can click it and hit the delete button and nothing happens. Somehow, Fusion has created an immortal line! Strangely, if I select everything in the sketch I can delete it all including the line. I should add that originally, this line was a construction line. It only became solid after I exited the sketch and then tried to extrude something in the sketch. So for some reason after that, Fusion either made this line solid or made a new line on top of it and made it impossible to delete specifically.
I can't attach the screencast because the Autodesk forum's own built-in "PASTE A SCREENCAST URL" and "MY SCREENCASTS" tools are still broken as they have been for years and cause the page to give itself an HTML error. So, here is a link to the URL of the screencast.
