Bug Report: arguments in MarkingMenuEventHandler are missing (NoneType) for sub components
OceanHydroAU
OceanHydroAU
This is a followup to my post in the other forum:  https://forums.autodesk.com/t5/fusion-api-and-scripts/bug-report-how-to-select-which-right-click-lin...
When users right-click on elements in the browser (e.g. on the "Bodies" of the root component), our MarkingMenuHandler receives a callback with an argument indicating what they right-clicked on (e.g. adsk::fusion::BRepBodies )
This works fine for the root component in the browser, however, for all submenus of any additional components in the browser, our MarkingMenuHandler receives a callback with only a single "NoneType" argument and no way to determine what the user right-clicked on.  (which might be "Bodies" or "Sketches" or "Flat Pattern" or "Origin" or "Construction" etc - always "NoneType" for those.)
You can reproduce and observe the bug with this sample code:-
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c90ce6a2-c282-11e6-a365-3417ebc87622
find this line in the above:
setLinearMarkingMenu(args)
and insert this code after it:
try:
    if args.selectedEntities.size:
        print(args.selectedEntities.front().__class__.__name__)
except:
    pass
then create a new design, create a body inside that design, create a new component in the design, and create a body inside this new component, and the right-click on both of the "Bodies" items in the browser menu to see the bug on the second one
You will see this working:
says: adsk::fusion::BRepBodies
And this not working:-
says: NoneType
I hope you like my bug report!  Good luck!
OceanHydroAU
Additional information (possibly the same bug) - the selected entity is not exposed to the commands either for sub components only (root is OK)
Running the commands we added to the right-click menu result in adsk.core.Application.get().userInterface.activeSelections.entity being "None" (for subcomponents - the top-level root components work OK)
example code:-
        class CommandCreatedEventHandlerPanel(adsk.core.CommandCreatedEventHandler):
            def __init__(self, pnlid):
                super().__init__()
            def notify(self, args):
                try:
                    app = adsk.core.Application.get()
                    ui = app.userInterface
                    print(ui.activeSelections[0].activeSelections.entity.objectType) # works for root, is None for components
