BUG - Rectangular pattern issues with surfaces
Errors and crashes using rectangular pattern on a surface.
To replicate :-
sketch circle and extrude a surface cylinder.
on a tangent plane sketch and extrude a hole through the side of the cylinder.
Use rectangular pattern, -> feature. Pick the extrude for the hole, then choose an origin axis for direction. Tool stops working correctly.
If you then fill in the rest of the pattern dialogue and ok it. nothing happens, but editing the pattern crashes fusion.
There is a work around by choosing to pattern a body, then changing to feature after everything is entered into the dialogue.
