[BUG] Pattern of a mirrored revolve
jagorL
Observer Observer
jagorL
Observer
Observer
I have created a part with a mirror of a revolve feature and then did a linear pattern of some features (including the revolve and mirror). Revolve cut through 2 bodies and pattern created another body as expected. But mirrored revolve feature is only applied to the main body of the pattern result. See screenshot and a Fusion file.
davebYYPCU
Um, you have attempted to pattern in one operation, (apple body 1 and orange body 2 combined)
As you can see, your pattern completes correctly for body 1, and Fusion when patterning features does not have advanced knowledge to include the mirrored feature from body 2.
(Bug? Maybe I don't know why but believe it's related to One feature owned by more than one body)
If it were me, I would rearrange the timeline to my example.  Proper result by patterning bodies instead.
Might help....
jagorL
Observer
Observer
I'm not really looking for a workaround. In pattern preview it shows it correctly, so I would consider it a bug.
TrippyLighting
This might be a bug - I have not time atm to look into this deeper - so I am going to tag @Phil.E .
However, your statement in respect to a "workaround" is unwarranted. Your workflow should by all means involve components. If it did you would not run into this potential bug.
Thanks for reporting and sharing your model!
g-andresen
I would create the extrusion 2 with the option “new body” and the pattern with compute type "optimized".
günther
