BUG: Paste New Component function is broken
jonwienke
jonwienke
The new instance of the component appears momentarily, then disappears, leaving the copy/move dialog with no selected object to work with. It is not possible to paste a new instance of a component that is not linked to the original. Paste works, but then any edits made to any instance (other than position) propagate to all other instances. I need to copy the component and edit the copy without the edits affecting the original instance, and I can't.
https://autode.sk/2RRTCPV
dsouzasujay
Hi @jonwienke ,
Can you attach the design that you have issue with paste new in Fusion 360?
You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
jonwienke
I can, but I'd prefer to send it privately, rather than post it publicly, as it's intended to become a commercial product.
dsouzasujay
Hi @jonwienke ,
You can send me the link at (Sujay<dot>dsouza<at>autodesk<dot>com).
or share the link in the private message.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
jonwienke
I sent you an email with a  download link. Please let me know if you have trouble accessing the file.
dsouzasujay
Hi @jonwienke ,
Thank you for sharing the design.
I agree with you that this is a bug and also annoying, reported as FUS-81941 in internal issue tracking system.
I will get back to you with possible solution or a workaround.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
