[BUG] It's not possible Paste New a component which contains copy of a Body
jnovacho
Observer Observer
jnovacho
Observer
Observer
If you create a component (Component 1), then copy body (Body 1) from the component to new component (Component 2) everything works as intended. You have two components with linked bodies.
Now when you want to create a copy of the Component 2 (with the copy of the body) and choose an option 'Paste New' to create independent component the process fails. You just get 'Move/Copy' dialog, but no copy.
Screencast and demo design are attached.
Fusion 360 info:
2.0.9719
Active Plan: Fusion 360, Personal
Windows 10 (19042)
jeff_strater
thanks for boiling this down to a nice, reproducible case.  What happens, I suspect, is that the Paste New fails, but Paste and Paste New both then invoke Move on the result, so the Paste New fails (silently, unfortunately), and dumps you into Move, with no selected target to move.  This is a bug, and I'll enter it.
[edit] the bug is FUS-78068
Jeff Strater
Engineering Director
