I appreciate all he "logical" conclusions that re drawn in this thread, but on further testing there is evidence that those conclusions are simply try to explain how the developer might have intended for the tool to work
However, even if that was the intention, it wasn't implemented properly, hence there is clearly a bug her!
I opened @TheCADWhisperer pattern bug design edited the existing pattern. Depending on what sequence of edits I use I get different results, which according to the aforementioned "logic" should not even be possible.
If anyone feels compelled to play around with this even more, perhaps enable suppression and suppress an instance, I predict results will still be different.
