Bug in parameter table?
terry_fusion
terry_fusion
Fusion 360 2.0.15289 x86_64
Active Plan: Subscription
Windows 10 Pro 22H2 (22621.1105)
Note: This is an insider build
Something is amiss with the latest update to Fusions parameter table.
Its not updating up my values in the parameter table as I change them?
And it wont pick up the value from another value when selected within the same sketch?
jhackney1972
Fusion 360 Insider Edition issues should be submitted on the Autodesk Beta site, not here.  The first reason is that no one without the Insider edition can test your issue and two, Insider editions are Beta and issues may occur thus the whole purpose of the Beta.  Return the the Autodesk Beta site and report your issue there.
John Hackney, Retired
seth.madore
Another aspect of the Insider to keep in mind; being an Insider is subject to an NDA, and posting images from such a build onto a public forum is not appropriate..
Seth Madore
terry_fusion
Could you direct me to the beta site? I've looked under the Autodesk forums and Help but haven't seen a link?
Thank you
terry_fusion
Good to know thanks
jhackney1972
The site is the same one you went to when you signed up for the Fusion 360 Insider program.  When you log into this address, you will see the Insider program.  It uses the same Autodesk ID and password you are using to log into the Fusion 360 version you are using now.
terry_fusion
I'm still learning to navigate Autodesks various site.
