Bug in Generate Face Groups Dialog
Julie_7
Julie_7
As you can see in the below screenshot, the selection field is cutoff to the point of being useless. In addition feature dialogs are not resizable so this is a problem.
The label for Minimum Face Group Size is also cut off.
Possible Solutions:
  - allow dialogs to be resized
  - auto size dialogs so that all fields are readable
  - reduce the dialog margins (The left margin could be reduced. The right margin should be reduced as it is extremely wide for no reason and is a large part of the "field cutoff" problem.)
jhackney1972
The Generate Face Groups dialog box is resizable.  I am using Windows 10 if that makes a difference.
John Hackney, Retired
Julie_7
I am also using Windows 10 and I could not resize it.
Interesting, today I can resize it. It is just very hard to get the resize cursor to display. I will see if I can adjust mouse sensitivity.
My comment about the right margin being larger than the left and therefore cutting off fields still applies.
