BUG: Drawing Sheet Title Block Paper Size Attribute
SPACERACK-Mat
SPACERACK-Mat
Bug: String replacement for the <Paper Size> for A4 sheets adds an extra space on the end to become "A4 "
Expected Behaviour: Paper Size attribute should be replaced with the string "A4" without a space on the end.
Steps to reproduce: Create a title block with the attribute <Paper Size> on an A4 sized sheet.
I know this is really pedantic, but it throws off center alignment on my title blocks with A4 drawings. It doesn't occur for any other paper sizes such as A3 or A2, it only appears on A4.
Pramod.kadam
Hi @SPACERACK-Mat ,
Thanks for reporting.
Can you please share the both drawings (with A3 and A4 size) with us?
Pramod Kadam
Product Owner
Fusion 360 Drawings
SPACERACK-Mat
Hi @Pramod.kadam, The issue is not specific to any drawing template but rather the Paper Size attribute in the title block editor environment. To demonstrate I have done a screencast using the default in-built ISO titleblock for the steps to reproduce the issue.
https://knowledge.autodesk.com/community/screencast/76f9a5f7-7984-4ac5-a645-b6c794b236a7
Pramod.kadam
Hi @SPACERACK-Mat ,
Thanks for the screencast. I will log a bug for this issue.
Pramod Kadam
Product Owner
Fusion 360 Drawings
ClintBrown3D
Hi @SPACERACK-Mat
Good news, this has been resolved in the November release of Fusion 360 (which should be available imminently)
More info here:
https://forums.autodesk.com/t5/fusion-360-support/november-2021-product-update-improvements-known-is...
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
