[Bug] Drawing disassociates all GD&T FCF's after re-opening file
bwalker145
bwalker145
Once again, Fusion disassociates all GD&T FCF's on my drawing after re-opening the file, with no changes to the CAD. I have to go through and re-associate each frame, for no reason. This has been a common occurrence.
It's easy enough to fix, but I shouldn't have to dig through all 19 pages and fix my drawing just from opening it.
Can share assembly with Autodesk if needed, not publicly due to customer data.
anirudha_kulkarniHVD7C
Thank you for flagging this issue.
To help us investigate further, could you please share the assembly and drawing files with us (anirudha.kulkarni@autodesk.com, pramod.kadam@autodesk.com)? Additionally, it would be helpful if you could provide the following details:
  • The version of Fusion you’re currently using
  • Whether this issue occurs with other files
  • Any specific workflows or actions you typically perform before issue occurs.
This information will help us narrow down potential causes.
Thanks again!
mohammed.aliTDPXK
Hello @bwalker145,
Sorry for the issue you are facing, please share the file with me on mohammed.ali@autodesk.com or you can send me a Direct message on forums as well
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
bwalker145
Hello @anirudha_kulkarniHVD7C @mohammed.aliTDPXK
Thanks for reaching out, I just sent you an email with links to the data.
To answer your question:
    • 2602.1.25 x86_64
    • Yes, this does occur with other files. I've had it happen with both simple & complex drawings. After fixing the disassociation, it usually does not occur again on the same file.
    • The disassociation occurs after re-opening the drawing file, with or without restarting Fusion first. Restarting Fusion after the disassociation occurs does not fix it. I can't think of anything specific in my workflow leading up to that point. I usually complete each sheet (standard dimensions first, then FCF's) before moving on to the next component/assembly. CAD is updated as issues are found, and the drawing reference updated immediately.
