BUG: Cannot create create closed spline with latest version of Fusion 360
Hi there,
I'm designing a fan blade and have been using Fusion 360 to make a 3D model.
What I have done in the past is to create the aerofoil shape in a fan design package, export it as a 3D CSV and then use the 'ImportSplineCSV' script (⇧S) to pull a spline from a file (like the attached file).
The next step was then to close the trailing edge (see picture 1 and 2) using a simple line, and then extrude/loft the profile.
The problem I am facing is that now when I close the profile at the trailing edge, it doesn't have the 'yellow/solid' colour that allows me to extrude. With past versions of Fusion 360 I have been able to do this no problem (last month it was working), but now I cannot seem to get the section to close.
Is there something that has changed in the latest version?
Can anybody else download the attached file and import it into Autodesk Fusion, close the trailing edge and extrude?
Is there any way for me to downgrade my Autodesk software?
