Broken / missing hidden lines
I'm relatively new to Fusion 360, and have had a look on the forum to see if anyone else was experiencing a similar issue (user error aside), but to no avail.
For some reason, when I view an object in 'Shaded with Visible Edges only' mode, not all of the hidden lines are shown - please see attached screenshots.  Any ideas how I can fix this?  Any help will be much appreciated.
Kind regards,
Lyle Mann
alessandro.gasso
Hi Lyle,
As you can read in the post below, the behavior is not correct, but the fix should be available soon.
https://forums.autodesk.com/t5/fusion-360-support/hidden-lines-do-not-show-correctly-in-model-view/t...
Thanks and regards,
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
Ah right, understood.  Thank you for the prompt response Alessandro, it is much appreciated.
Kind regards,
Lyle Mann
alessandro.gasso
My pleasure!
Alessandro Gasso
Autodesk, Inc.
