Breaking apart "Interconnected" ensembles so they can be 3D printed in parts?
patrick_william
patrick_william
Please click on video
https://www.screenpresso.com/=X5vDd
Also as a side note the attachment is what my computer is defaulting to where before I was able to send people the whole file in question... something is up with the setting on saving because wehn I save it to my computer it saves it as the attachment in this note.  Can people click on the attachment and see the project with time time and etc?
thank you
Ruud1
Hi Patrick,
It happens that I've just created a post reporting that this function does not work.
Below is the supposed workflow:
patrick_william
I looking into it too... see this... I have not tried it but maybe this will work
Ruud1
That solution will take a lot of time to execute.
I've created a script which will export all selected bodies as seperate files. See the attached file. Use the below video as a work-instruction.
  • Unpack attached.
  • Go to Utilities > Add-Ins > Scripts And Add-Ins
  • Click on the '+' icon and select de folder location
  • (close menu)
  • Select all bodies (Note; the script only checks for bodies. Nothing else.)
  • Run the script through previous dialog.
Hope this helps!
g-andresen
have a look at my reply (#2) in this thread
günther
