boundary fill for creating obstacle geomentry
Hello everyone,
I have been trying to create a solid body for obstacle geometry filling a hollow space of a preserve body. Can someone please help me on how to create this body ?the space here is where the obstacle geometry is to be createdthe space here is where the obstacle geometry is to be created
mohammed.aliTDPXK
Hello @Anonymous ,
I would recommend you to just try the edit model workspace within GD.
Here you can just try and create a solid body of required dimensions based on your requirements and main advantage is , the changes you make in edit model won't actually effect your main design.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
jeff_strater
@Anonymous - today, Boundary Fill is not available in the "Edit Model" environment in the Generative workspace.  So, you will have to do this in the Design workspace.
To make Boundary Fill work, you just need to add workplanes at the top and bottom of this volume, so that a completely closed area is defined.  If you share the model, we can show you on your model.
Jeff Strater
Engineering Director
@jeff_strater thank you for the reply. I was able to solve the problem based on the information you provided
