'boost::filesystem::status: Permission denied:' error opening files between computers!? help!
luresKQFHC
luresKQFHC
Recently had to send my main computer, Macbook Pro into get serviced, so started to use my IMac to continue working with fusion 360. Now I have my Macbook Pro back, I can't open a lot of files - am getting the following error.
Please advise as have deadlines I need to meet... Is there a work around?
dsouzasujay
Hi @luresKQFHC,
Sorry to see that you're facing this problem.
Please follow below steps to fix the problem
  1. go to below folder location
    • C:\Users\[YOUR USER NAME]\AppData\Local\Autodesk\Autodesk Fusion 360\[UNIQUE OXYGEN ID]\W.wwwwip1fqa
  2. Take a backup of 'F' Folder (Copy the F folder to different Location)
  3. Delete all the files and folders in "W.wwwwip1fqa"
  4. Restart fusion and see if the problem got fixed
If the issue still happens, then please send me complete log files
You can collect them from
  • Help -> Support & Diagnostics ->Diagnostics log files.
  • This will generate a zip file that you can upload.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luresKQFHC
Thanks for the reply but as outlined in my post I am using Mac OS, where can I find this?
dsouzasujay
@luresKQFHC,
Im sorry, I missed to read.
Here is the location for F folder in macOS
/users/<username>/Library/Application Support/Autodesk/Autodesk Fusion 360/<oxygenID>/W.login
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
@luresKQFHC,
Before taking backup of F folder, can you please collect Diagnostic log files and attach here to the next reply?
and also confirm, If the same machine was used by multiple users to login Fusion 360 application?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luresKQFHC
Sure please see attached.
That solution seemed to work. I will let you know if I encounter the issue again.
No, not different fusion logins/users. Just different MacOS logins, which where I think the problem is. One install is on the Imac under as 'local admin', the other is on the Macbook Pro using a custom user.
