Body rotates if angle of 2D Sketch changes - Joint problem
locjeffery
locjeffery
Hello together,
I am again struggeling with joints ... I hope you can help me out.
What I am trying to do:
I have two lines crossing with an angle that can be changed in the parameters (see sketch).
Then I "Insert Derive" a Sketch that I connect via Joints to each end of the lines to then extrude/sweep.
The problem is that when I change the angle in the parameters, the body rotates weirdly.
I tried it with additional Joint Origins and additional lines in the sketch but nothing worked.
What am I doing wrong?
And is there a comprehensive Guide on my "2D Joint"-problem? All videos I find on Joints are more "basic" and on 3D geometry.
Thank you very much in advance
g-andresen
I recommend using joints that are defined via 2 axes.
günther
