Bodies appear differently than joint configuration
I am trying to simulate fixturing for a CNC mill operation by using a serrated and v grooved jaw. My goals are to make the bodies parallel and bottom surfaces align to the same plane. (if you can image how they would slide on a vice)
One issue Im having occurs when I close the joint window the bodies revert back to their original orientation as if the edit I made did not go into effect. How can I make the bodies appear as they are depicted in the joint window? ( see images below)
IMAGE 1: view of bodies while having the edit joint window open.
IMAGE 2: Body position after closing edit joint window. If you look closely, they are slightly angled. (bodies do not match set up in IMAGE 1)
Thanks!
