Hello, I have read the other post about this matter... and have found that I am having a slightly different issue that the others who have/had issues with Fusion rendering boards.
I have about 20 projects or so. Of the 20, 19 appear as they should after I push them to Fusion. However 1 does not. The difference between the boards I have that do render correctly and the one that does not render is the length of the PCB. The one that does not render properly is 19.6" long. When it renders, parts are shifted out of place, and the "green area" is cut shorter than it should be. So as a test, I started making it smaller and smaller in 1/2" increments. As I did so, the problem with shifted parts got better and better and the green area was less and less "cut off".
An interesting side note... parts in the center are not "shifted". It appears to me the parts may be in the right place, but the boards "top layer" is not being rendered correctly. A picture is worth a thousand words, so please see attached image below.
Thank you in advance for your help!
Dave Perotti
