Blurry / Pixelated Text in Sketch
Hello Autodesk Community,
I am new to Fusion 360.
I want to create text in sketch which is not blurry. Currently I am getting blurry / pixelated text...
My current method to create text:
- Select 'SKETCH'
- Select 'Create Sketch'
- Choose a plane
- Select 'SKETCH'
- Select 'Text'
- Select point
- In the 'Text' field I write the desired text, e.g. DM
- In 'Height' I adjust the size of the text, e.g. 100.00 mm
- Select 'OK'
- Select 'STOP SKETCH'
Using the method described above I get the following sketch (I have zoomed in a little to highlight the extent of the pixelation):
I do not seem to have a problem with any other sketch elements and objects/forms. It is only when I use text that the sketch is blurry.
When I extrude the text the objects created are smooth:
Similarly, when I explode the text the sketches created are smooth:
Currently I am exploding all text...
It is quite strange why this is happening. I have tried fix mentioned here with no luck:
Adjusting Windows 10 display scaling settings for Fusion 360
I tried Application, System and System (Enhanced). After the Windows 10 update, the interface is slightly different from the one shown here but I got the gist.
I am using the following system:
OS Name: Microsoft Windows 10 Home
Version: 10.0.17134 Build 17134
System Manufacturer: HP
System Model: HP Pavilion Notebook
System Type: x64-based PC
Processor: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz, 2904 Mhz, 2 Core(s), 4 Logical Processor(s)
Installed Physical Memory (RAM): 8.00 GB
Total Physical Memory: 7.89 GB
Available Physical Memory: 3.86 GB
Total Virtual Memory: 9.76 GB
Available Virtual Memory: 4.76 GB
Page File Space: 1.88 GB
I am using the following software:
Autodesk Fusion 360
2.0.4126
Active Plan: Fusion 360 Ultimate, Trial
Expires: June 07, 2018
(I know I could have print screened the information but it is better to write it so it can be copied/shared more easily)
