Blacked out toolbars after update
huren
Observer Observer
huren
Observer
Observer
Some of the students is my class have found their toolbars are blacked  out after the most recent update. The buttons are available under the black section. Probably an easy fix, but please help.
mohammed.aliTDPXK
Hello @huren ,
Sorry for the issue you are facing.
can you please try the below steps ?
One potential workaround is to force Fusion 360 to use software rendering by setting a system Environment Variable.
  1. Right-click on My Computer/This PC on the Desktop or in the Start Menu and select “Properties”
  2. In the left column of the System window that appears, select “Advanced System Settings”
  3. Within the System Properties window that appears, click “Environment Variables” in the bottom right
  4. Within Environment Variables, click “New…” under the System Variables section
  5. For Variable Name, enter QT_OPENGL
  6. For Variable Value, enter software
  7. Click OK to save the new variable
  8. Launch Fusion 360
let me know if this helps.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
