Super annoying bug here that is actually making Fusion 360 unusable for me right now.
When working in my sketch, I cannot edit the dimensions of a sketch object once a constraint has been added to a feature - even though the dimension should not be constrained at all.
Please watch the screencast to clarify. You will see me try to change the dimensions on a few ellipses and rectangles. You will see that the dimensions of shapes that have a constraint to some geometry can no be edited (even though they should be). You will see me freely change dims on shapes that are unconstrained, but once I constrain them to some other geomety, the dims are locked, with a bunch of bogus errors. Oddly enough, after adding a geometric constraint, you will notice I can set a dimension once, but then I cannot edit it (even back to the original dimensions!
You can imagine this makes it near impossible to make any edits.
This seems to be a straight up bug. I haven't made any changes to my system that would explain why I can't edit files that were working fine previously. Not sure if there was an update over the last few days that could have caused it.
