Bending sheetmetal overlap
BvanT
BvanT
Hi Folks,
Sorry for this very noobish question but I am trying to learn sheet metal design and I can't seem to get this to work.  I am using 1.2mm stainless and I would like to attach two plates (with screw).  The problem I am having is that I can't seem to manage to create a flange that will be just under the left sheet.
I have tried overriding bend radius but that gave errors and/or very strange results.
Can anyone point me in the right direction please
Thank you
carl.j.barker
I would generally use a sketched contour flange.
Useless you have a forming tool to manufacture the joggle you're not going to get 90 degree bends on a press brake, which is what all fusion sheet metal is aimed at.  For now.
Hint to devs. give us forming, normal cuts and lofted flanges please.
BvanT
Thank you Carl, I will look into sketched contour flanges and how to do that.
