Bending metal
Bending metal
infoYYJRS
Message 1 of 14
Bending metal
infoYYJRS
How can i bend and entire component i have mad with all its features?
Replies (13)
Message 2 of 14
g-andresen
How to bend?
günther
Message 3 of 14
infoYYJRS
Yes i want to bend it for a render.... in reality this bend would be done after the cut has been made...
Message 4 of 14
g-andresen
how should it be bent?
horizontal, vertical, diagonal; at which position > which radius > which angle
günther
Message 5 of 14
wmhazzard
You can bend it by joining a sheet metal body to the body to be bent and then refold.
Message 6 of 14
infoYYJRS
So the bend is an organic form.
Message 7 of 14
g-andresen
this can be done according to the principle shown in the screencast.
Also follow the steps in the timeline.
günther
Message 8 of 14
infoYYJRS
Wow! Okay thats a super nice feature.
But right now i already have it unfolded and need it folded around the organic form
Message 9 of 14
g-andresen
If you want a curved object, go to the SHEET METAL section and create a flange on your spline curve.
Extend this flange slightly with the extrusion tool to get an "flat“ base area for unfolding.
Select „unfold“ tool and mark this sector to unfold the sheet metal body. Then it can be processed and refolded.
Please show pictures of a real existing object, so you know what it is about.
günther
Message 10 of 14
infoYYJRS
Dear Gunther,
So i have drawn a bracelet  flat and now i want to bend it.
If i understand you right i need first to "bend it" then  "unbend it" then draw my pattern.
When you write  pictures do you mean pictures of  the actual object?
Message 11 of 14
g-andresen
@infoYYJRS wrote:
...do you mean pictures of  the actual object?
I mean a real existing object close to what you want to achieve.
günther
Message 12 of 14
infoYYJRS
@g-andresen i have DM'ed you the images 🙂
Message 13 of 14
g-andresen
here´s a screencast and the file in the attachment.
Follow the timeline
günther
Message 14 of 14
g-andresen
Here´s another model.
The lengths of the parts were coordinated and patterns were added.
However, this leads to a considerable amount of work (time) for the calculation when bending back because of the number of faces.
günther
