Bend Note Incorrect labeling in drawing
jamesrose3WXP3
Observer Observer
jamesrose3WXP3
Observer
Observer
I've had this happen a bunch of times.  Sheet metal part with different degree bends example two edges bent down 45degrees and center bent down 60degrees.  when I do drawing of flat pattern and use bend note to mark the degree of bend it labels all three bends either 60degrees or 45 when the center should be different degree than the outer two.
ClintBrown3D
Hi @jamesrose3WXP3
I'm sorry to hear that you are having trouble. Please can you share an F3Z from your drawing file for us to have a look at? You can attach the F3Z file here, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
