There are two things that I noted from the log files, thank you for sharing them.
The first thing is that there is something in the upload queue. I'm not sure if it is stuck for some reason or not.
If you browse to:
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\***\W.Login\Q
You'll see there are a couple of files in there. As far as I can tell, they seem like they may be stuck. The file name is POE_RND_170416-A.
Could you try the following?
1. Enter into Offline mode
2. Open POE_RND_170416-A
3. Save a new version of this design
4. Go back online and see if the design will complete syncing.
Is POE_RND_170416-A by any chance an X-referenced component of the Jolt_Rnd_E01 file mentioned in the log files, below?
The second thing is that I'm seeing this document save was cancelled repeatedly in the log files.
20170504T082717 E Failed to backup file ***/Roaming/Autodesk/Autodesk Fusion 360/***/CrashRecovery/86f14f010f1f449c85ec7d073c73e0ef.backup to crash-recovery folder
20170504T082717 I Problem autosaving document: Jolt_RnD_E01 (v4~recovered), status: Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...+Document save was cancelled ...
I think this has something to do with the auto-save taking longer than expected. I'm not sure if the pending upload could cause this, but I'm hoping if we solve the sync issue it will also save the auto-save issue.
I look forward to your update. Please let me know if you have any questions. I am happy to help.
Nathan Chandler
Principal Specialist
