Automatically Capture Position
sutherland-
sutherland-
Is there a way to automatically capture design position after I have moved a component?
I am using "No Component Drag" add-in, so I do not have to worry about accidental/unwanted position capture.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
TrippyLighting
No and that would also be terribly undesirable.
To locate components, use joints.
jeff_strater
In theory, this should be taken care of for you.  If components are in a moved position, any operation that depends on component position should prompt whether to capture position or not.
However, @TrippyLighting is right - too many Capture Position features in your timeline is not desirable.  In a large assembly, those can negatively affect performance.  And, using Joints is, indeed, much better than Move/Capture as an assembly mechanism.  Capture Position is really intended for doing "position-based modeling", which is useful, but probably not all that common.
Finally, you should no longer need the "no component drag" add-in.  Disabling component drag is now available in parametric designs (I added it myself):
Jeff Strater
Engineering Director
